First post, by dosfreak70
Hello,
I need some help in connecting my PC via the printer interface (parallel) with another communication terminal.
The old DOS soiftware should enable me to read and write the memories / registers of this terminal. The old software - ComDat - runs perfectly and it connects via LPT1 to the teminals printer interface (with a Laplink cable).
However the command "download register" responds wit a black DOS window and the Message: "Achtung! Interner Programmfehler bei der Speicherallokation über den Heap" which means: Attention! Internal program error in memory allocation on the heap. (see attachment)
Does anyone has an idea what to do or amend in the DOSBox configuration file?
