First post, by PhoenixTW
Hi guys
This probably has been posted before but I really am getting stuck trying to find any helps on this issue, even when I find a thread with solutions they don't work for me.
Deeper Dungeons isn't working on my DosBox, it either comes up with the ? disk symbol upon startup (after the startup vid) or it boots to the menu and when I select "Deeper Dungeons" it asks for the disk to be inserted.
Here is what I have and what I have tried:
I actually have, it appears to be rare, a two disk version of the Gold Edition; one for Dungeon Keeper and one for Deeper Dungeons. Using the guides I have found I installed Dungeon Keeper fine to DosBox and it runs perfectly.
With Deeper Dungeons I installed by doing the following:
Booted DosBox, "mount d E:\ (my cd drive) cdrom", "D:\", "D:\Setup" and then follow the steps where it asks for language select and then to type the install path of Dungeon Keeper which I input as "C:\Keeper", no problems encountered.
Then when you try and play it I encounter one of the two problems above.
I have tried downloading a gold edition iso and mounting the image, but from what I can gather all DD needs is a disk in the tray which is labelled KDDISK1 but my Deeper Dungeons install disk is labelled that anyway and still won't work (image mount or original disk).
Another thing I have tried is installing a downloadable version of Gold Edition, that didn't work. Also tried editing KEEPER.CFG to state that actual install folder rather than the default D:\KEEPER, and that didn't work either.
Sorry if this has been covered but I really can't find ANYTHING, especially with anyone who has a two disk version.
Thanks in advance.
