Grand Prix 2
First post, by Philip00
Hi all
I have 2ghz amd athlon asus a7n8x deluxe motherboard 512 mb ram, saphhire radeon 2600 hd pro graphic card in Win xp. I play gp2 via dosbox 0.74 but it's very slow, why? i alredy did put more cycle(ctrl+f12) but always same(only 14 frame per second in Svga mod) . please help me and sorry for my bad english
Reply 1 of 5, by collector
Check out these two guides:
60 seconds guide to getting your game to run in DOSBox
How to speed up DOSBox (by robertmo and mirekluza)
If you still have problems, post everything that you have tried for more help.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 2 of 5, by Philip00
collector wrote:
Check out these two guides: […]
I tried everything and it faster little bit but in te game i can set 14.2 frame per second (and i disable lot of function in graphic setting), i don't understand why, maybe my computer not strong enough?
Reply 4 of 5, by VileR
3D SVGA games can be *very* demanding on DOSBox - remember that everything has to be emulated in software. 14 fps sounds logical for a game like this on the hardware you have.
I suspect that the only way to get good performance would be lower resolution.
Reply 5 of 5, by Procyon
Here are some suggestions you can try by finding the following lines in the .conf file and edit them:
output=overlay (generally the fastest graphical output)
core=dynamic (some games can be really sensitve about this)
cycles=max (this will give you all cpu power available to you)
timed=false (this is only needed if you intend to play with an analog controller)
