First post, by Ashir
Hi guys, I have two questions:
1. Is the 3DFX version of Whiplash working with the glide emulation?, if so, what's the config to make start?
2. Any config to make this heavy game more smoothly?. Right now I'm running it with a Core i7 @ 3.6 GHz and 12 GB RAM using Dynamic/Max and I'm having about 25 FPS (says fraps).
I'm using D-Fend Reloaded v1.3.4 and DOSBox 0.74.
Thanks.
Reply 1 of 4, by Gamecollector
1. No. The game is using statically linked glide and is working only with a real Voodoo1 or Voodoo2.
2. More raw processor power. Because glide for this game is emulated by CPU only.
25 FPS? Are you sure there is no in-game FPS limiter in Whiplash?
Reply 2 of 4, by Stiletto
I found this a little confusing to read, so a re-work....
1. Due to Whiplash using statically linked Glide, this game should in theory work with kekko's 3dfx Voodoo emulation patch for DOSBox (built in to ykhwong's DOSBox Daum builds, among others?). It will not work with gulikoza's Glide wrapper patch.
do the Fandango!" - Queen
Stiletto
Reply 3 of 4, by Ashir
I didn't explain myself right enough. I mean, a config for software mode. I'm having about 25 FPS in software mode...
Reply 4 of 4, by Ashir
Well I just download ykhwong's DOSBox Daum build and you were right, it runs!.
Wow, this game never runs so smoothly before... A real shame you lost full GUI while using 3DFX executable 😢
Thanks anyway...
