Dial8 and 376x564 Mode X Resolution
Having problems with a specific game or application? Post your problems here!
Postby kolano » 2014-2-28 @ 16:59
My prior post seemed to get bogged down with details around DOSBox doubling the width of Mode X modes with vertical resolution 400+. Still trying to work out rendering Dial8's 376x564 Mode X resolution (i.e. it's mode 11).
svga_s3 vs vgaonly:
With either machine type, I get only 376x282 resolution output.
linewise and multiscan:
With either linewise or multiscan turned on individually I also only get 376x282 resolution output. With both enabled I get 752x564 output, but it's just that the pixels are doubled in both directions.
Either way it seems like only the top half the image is output.
Can anyone let me know if it's possible to get the 376x564 output in DOSBox? If so, how? And if not, why?
User avatar
kolano
Re: Dial8 and 376x564 Mode X Resolution
Postby ripsaw8080 » 2014-2-28 @ 22:20
Have you seen the 376x564 resolution working correctly on real VGA hardware? I'm guessing the answer is no, because it appears the program has an obvious bug. I looked at the mode 13h register tweaks used for 376x282 (option 4) and 376x564 (option 11) -- they're identical, and that's clearly not right. However, this bug or flaw is not difficult to fix: modify the byte at offset 87F5h in the executable from 61h to 60h and the 376x564 resolution will work as expected.
User avatar
ripsaw8080
DOSBox Author
Postby h-a-l-9000 » 2014-3-01 @ 02:13
It looks the same on real hardware.
1+1=10
h-a-l-9000
DOSBox Author
Postby h-a-l-9000 » 2014-3-01 @ 02:51
Wonder if there is a CRT that can display it properly :)
1+1=10
h-a-l-9000
DOSBox Author
Postby ripsaw8080 » 2014-3-01 @ 05:47
Are you talking about before or after patching the program so option 11 isn't using the exact same register tweaks as option 4?
User avatar
ripsaw8080
DOSBox Author
Postby kolano » 2014-3-01 @ 07:28
As you've noticed I can't speak of how it works on real hardware, but can confirm that Ripsaw's patch fixes the issue (at least in DOSBox).
Thanks a lot Ripsaw for providing a fix for this. I had been going crazy trying to work out if there was a DOSBox config solution to the problem. I very much appreciate all the help you provide here. You do an awesome service for folks still loving DOS software, thank you so much.
I should have a patched version, along with a DOSBox pre-config /w the program up on my site soon. I'll update this once I do.
User avatar
kolano
Postby h-a-l-9000 » 2014-3-01 @ 11:10
ripsaw8080 wrote:Are you talking about before or after patching the program so option 11 isn't using the exact same register tweaks as option 4?
I don't think your patch makes a difference there. It appears that vrstart is lower than vbstart, causing retrace lines visible in options 4 and 11. The border at the bottom is wrapped into the display.
Two options to fix that:
- decrease vbstart. The border will be cut at the bottom.
- increase vrstart. When turning up brightness quite a few blank scanlines are visible at the top. It seems there is enough room.
The horizontal lines on the photo are caused by the camera.
(87.95 KiB) Not downloaded yet
1+1=10
h-a-l-9000
DOSBox Author
Postby ripsaw8080 » 2014-3-01 @ 11:32
Changing the address line total in the maximum scan line register doesn't make a difference? How can that be the case? Maybe the problems with retrace and blanking make it a moot point?
This behavior in DOSBox is why the patch makes a difference there:
Code: Select all
    if (!(IS_VGA_ARCH && (svgaCard==SVGA_None) && (vga.mode==M_EGA || vga.mode==M_VGA))) {
        //Only check for extra double height in vga modes
        //(line multiplying by address_line_total)
        if (!doubleheight && (vga.mode<M_TEXT) && !(vga.draw.address_line_total & 1)) {
            vga.draw.address_line_total/=2;
            doubleheight=true;
            height/=2;
Thus doubleheight=true for option 4, and after patching it's false for option 11.
User avatar
ripsaw8080
DOSBox Author
Postby h-a-l-9000 » 2014-3-01 @ 12:32
Oops, that's a misunderstanding. Your patch works fine. But it doesn't help with the retrace lines on the photo.
1+1=10
h-a-l-9000
DOSBox Author
Postby ripsaw8080 » 2014-3-01 @ 12:58
Hmm, do you think exchanging the values for vbstart and vrstart would fix that? Maybe that's more than necessary...
For your suggestion with changing only vrstart, try modifying the bytes at offsets 86DDh and 87F9h from 37h to 47h. This will change vrstart/vrend from 567/569 to 583/585. DOSBox doesn't care, but maybe your CRT will. ;)
User avatar
ripsaw8080
DOSBox Author
Postby h-a-l-9000 » 2014-3-01 @ 21:59
With these changes the retrace lines are fixed.
I've hooked it up to a TFT and saw that the monitor is driven with 30kHz/50Hz. That might be out of range for several monitors. The Casper one I'm using is capable of CGA/Herc/EGA/VGA/800x600 reasonably, so it has no problem.
1+1=10
h-a-l-9000
DOSBox Author
Postby kolano » 2014-3-02 @ 00:22
OK, a patched version, per Ripsaw's initial patch, is now available from my site...
http://eyecandy.gnugget.net/Dial8/
H-a-l-9000/Ripsaw, are the later revisions you guys discussed just related to getting it working on specific displays, or are they generally needed? I know DOSBox doesn't seem to care, but would like to provide a patched version that works generally.
User avatar
kolano
Postby h-a-l-9000 » 2014-3-02 @ 18:09
That latter change would also make sense IMO. On the old 80ies CRT it removes the retrace lines and gets the border shaped identically on all sides. On a newer, maybe 1998 17" CRT the retrace lines are blanked automatically but the border width is also fixed. A more modern TFT screen will center the picture better on auto-adjust with the change.
1+1=10
h-a-l-9000
DOSBox Author
Postby kolano » 2014-3-03 @ 20:39
Patched version on my site now includes both patches. Thanks everyone.
User avatar
kolano
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: palxex and 3 guests
