First post, by mr_zen256
Hey folks, X-Com Apoc works brilliantly with DOSBox now, the only issue I have found is the save games wont load if you try to load them from the main menu. There is an easy fix for this. Just start a new game and load your save game from there. No crash - no error... SWEET
Now, go kick some alien ass
Reply 7 of 11, by Grein
Could you be so kind and paste the solution from there over here? Because I cant get Xcom-Apoc running neither, not even with DosBox 0.61, I always get kicked back to the dos-prompt after the intro ran through.
Epox 8k9a
Athlon Xp-1800
PC-266 512 MB Infineon RAM
Asus 8460 Geforce 4 ti-4600 ultra
Hercules Gamesurround Fortissimo
SCSI-only system
Reply 8 of 11, by mr_zen256
Well, at the moment I am using the current CVS and it is working fine with X-Com apoc. Here is my "dosbox.conf" file:
[sdl]
fullscreen=false
fulldouble=true
fullfixed=false
fullwidth=1024
fullheight=768
output=opengl
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
[dosbox]
language=
machine=auto
memsize=64
[render]
frameskip=3
snapdir=snaps
aspect=true
scaler=none
[cpu]
core=normal
cycles=13500
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
wavedir=waves
[midi]
mpu401=true
device=default
config=
[sblaster]
sblaster=true
base=220
irq=7
dma=1
sbrate=22050
adlib=true
adlibrate=22050
adlibmode=adlib
cms=false
cmsrate=22050
[gus]
gus=true
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=22050
tandy=true
tandyrate=22050
disney=true
[bios]
[dos]
xms=true
ems=false
[modem]
modem=true
comport=2
listenport=23
[autoexec]
mount c c:\oldgames
mount d f:\ -t cdrom
c:
Reply 9 of 11, by Whitewashed
The intro works, with sound, there area few graphical glitches though. But after the intro the screen just flickers and it goes back to the DosBox D:\XCOMA prompt... I tried without sound but it's still the same. How come it works for you but not for me? 😠
P4 2.6GHz 800MHz FSB
ASUS P4P800 (I865)
2x512Mb PC3200 DDR
ATI Radeon 9700 128Mb
SB Audigy2 Retail
160Gb SATA 7200RPM, NTFS, FAT32
LG DVD 16/48X
Windows 2000 SP4
Reply 10 of 11, by Whitewashed
I've got DosBox .61 and I tried using the settings posted here
ASUS P4P800 (I865)
2x512Mb PC3200 DDR
SB Audigy2 Retail
LG DVD 16/48X
Windows 2000 SP4
