First post, by Double-C
Hi...
I tried to run Stonekeep with DOSbox. But it failed.
When I try to start, this message appears:
"config.sys needs to be edited with FILES=15"
What should I do?
Greets
Double
Hi...
What should I do?
Greets
Double
don't upgrade it to 1.05 😀
keep the 1.02 works fine
Btw general discussion isn't for your game problems. Use the games forum for that. I'll move this message to it.
Water flows down the stream
Sorry... and thx 😀
but what shouldn't I upgrade?
The game? It's original and I didn't upgrade it 😒
Now its running... 😀
but its jerking 🙁
I recall there being a show stopper bug later in the game that needs the patch to be fixed. I've run into it everytime I've played the game and I've needed the patch each time.
ok thks...
I will look for the patch 😀
But, what about the jerking?
Its running very slow:-/
Which config is the best?
Greets
Chris
Where could I find the patch? 😒
14 minutes searching is short.
We aren't your mother. Try doing something yourself.
About that jerking question. The answer are out there.
Like in the readme of dosbox and realizing dosbox emulates a pc.
