First post, by sel666
Hi,
for some reason ultima 4 with upgraded graphics doesn't work properly in the new version of dosbox. the intro screen looks garbled and the actual game graphics do not use the patch update for some reason but the normal ones. for some reason ultima 5 (with upgraded music) does work in this version, while it didnt in earlier ones. seems i can never get both to work at the same time.
Reply 1 of 6, by DOS_Boy
i couldn't get ultima VII to work on 0.61 either, it says i have to diseable the dos memory extender. is there any way i can do this??
"But listen to me brother, you just keep on walking, 'cause you and me and sister ain't got nothing to hide..." - Scatman John
Reply 6 of 6, by MajorGrubert
You need to set machine=vga in your dosbox.conf file in order to get the patched version of Ultima 4 to work under DosBox 0.61. The game is getting into trouble when it tries to detect the video card under 0.61, probably due to the new Tandy emulation. Setting DosBox to VGA solves this problem.
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
