First post, by Un Information
I don't know what I am missing, I have properly installed GUS and it works for sound effects but not music. This is the case for both DOOM 1 and 2 and all of the expansion packs and mods.
OS: Windows 7 64-bit HP
Emulator: DOSBox 0.74
GUS config:
[gus]
# gus: Enable the Gravis Ultrasound emulation.
# gusrate: Sample rate of Ultrasound emulation.
# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
# gusbase: The IO base address of the Gravis Ultrasound.
# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
# gusirq: The IRQ number of the Gravis Ultrasound.
# Possible values: 5, 3, 7, 9, 10, 11, 12.
# gusdma: The DMA channel of the Gravis Ultrasound.
# Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir="I:\Program Files\DOS Box\ULTRASND"
