First post, by Hazekel
- Member
Strange problem here. I have Lost Vikings and it runs fine in DOS with PC sound. When I try to use DOSBOX, however, it keeps saying copy protection failed. I run the setup through DOSBOX and I do not even get the option for copy protection, and it didn't work the first time either (when the option was available). Why is this?
