Reply 20 of 31, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The installer just unzips the archives and writes out the .CFG file, it doesn't do anything else to the installed files. There was nothing wrong with the thread starter's files, the game just wasn't properly installed.
Reply 21 of 31, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Now I'm puzzled and don't understand. Will need to look myself to see what's different/not correctly installed
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 22 of 31, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The problem in this case could have been in correctly following those installer-less installation instructions on the Exult page rather than some deficiency in them. 😉
Reply 23 of 31, by Horkalite
As a followup, I compared the md5 checksums of the resulting files if I installed U7SI with INSTALL.EXE versus the manual install. The md5 checksums were equivalent.
Then I noticed that some files were being placed in the root directory (i.e., the C:\ directory, not the C:\SERPENT directory). At one point I saw a MAINBOOT file after using INSTALL.EXE. And at another point I saw a FILELIST.CFG file (although I'm not quite sure at what point that was generated). They were both 1kb binary files that had no human readable content.
The strange thing is that if I place either file into the root directory of my U7SI manual install that did not work before, it suddenly starts working.
Anyway, it appears that the correct installation procedure creates extra files that the manual install does not. And then the SI.EXE program checks for the presence of those files and if it doesn't find them, aborts.
Reply 24 of 31, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Seems to be a form of copy protection. The installer creates a file in the root directory containing some encrypted info, the filename being randomly chosen as EMS.CFG, DOS.UTL, DRIVER.CNT, MAINBOOT, or FILELIST.CFG, which I guess looks important enough to discourage people from deleting it, and both installer and game executables go to some trouble to keep those filenames hidden. Serpent Isle also has a documentation-based protection not long after the game begins, so apparently more concerned with protection than Black Gate.
Reply 25 of 31, by Dominus
DOSBox Moderator
BG has the documentation based protection as well on two occassions in the game (SI also two).
But the floppy protection only on SI and that very half assed because every good copy program could deal with that... There is a help text somewhere for U7 that mentions that for SI you need to have the original disks...
Reply 26 of 31, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The contents of the file don't seem to matter, or at least the game doesn't complain about it right away, so perhaps a check for proper installation rather than protection. If it truly doesn't matter what's in the file, you could update the installer-less installation instructions for SI to create one of the files in the root.
Reply 27 of 31, by Dominus
DOSBox Moderator
Maybe I'll just update it that for a working game you need to do a real install. The purpose of the instructions are NOT to have a working game but to get the data files (everything in the STATIC folder) which the manual installation does just fine 😉
Reply 28 of 31, by Dominus
DOSBox Moderator
OTOH it's so easy that I can just add this info 😉
Reply 29 of 31, by Dominus
DOSBox Moderator
Horkalite or Ripsaw, could you image disk 5 for me? My floppy disk has bad sectors.
I've spent the last few nights imaging my floppies and it's saddening how many have gone bad. My Spanish Serpent Isle has three bad disks out of 8, English SI one bad disk out of 7 and both add-ons for U7 are bad ;(
On the bright side Black Gate's disk are all good.
Reply 30 of 31, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Does your SI.EXE in the SIDISK00 archive on disk one match the MD5 that I posted or the one Horkalite posted? I think it'd be best to get disk 5 from the matching release.
Reply 31 of 31, by Dominus
DOSBox Moderator
heya, finally had time to look at it.
My SI.exe md5 matches Horkalite's
