First post, by Xian97
- Member
I noticed on http://dosbox.sourceforge.net/comp_list.php?letter=T that Magic Candle 1 and 3 were listed but not Magic Candle 2. I got my disks out and tried it and it loaded but I could not move the character since it used the Num Lock that I have seen from other posts is a known issue with DosBox. It is playable if you get the 2.0 update which adds mouse support so that you do not have to use the numeric keypad.
