First post, by monster166
First of all i want to say THANK YOU for making dosbox working in protected mode and i tried Nobunaga Ambition 2 with it. It work fine but the only problem is that i am not able to use the numpad section of the keyboard to enter numeriacl inputs into the game. This aspect is quite important as games like nobu and rtk will need the use of the numpad for ease of playing.
So my question is that can we mapped the numpad with the numbers so that they function exactly like the numbers??
Thanks for the help
Reply 1 of 1, by Silencer131
Does the game not accept numerical inputs from the normal number line on the keyboard? Those are the same number inputs the numpad uses. Otherwise try activating/deactiving NUMLOCK and see if that works for you.
If that doesnt solve it, describe the problem a bit more detailed. Right now it sounds as if you wanted to type in numbers via the numpad which you could also type by the normal number line on the keyboard.
