First post, by NewRisingSun
The game Elysium puts its saved games into a folder PICTURE\⌂, meaning ASCII 0x7F. DOSBox refuses to create this folder, and if I create it myself, it refuses to mount it. That means that saving/restoring is not possible. DOSBox should allow ASCII 0x7F in file and directory names.
Reply 1 of 7, by keropi
What a strange directory name to use... surely a remnant from the amiga where dos naming restrictions do not apply (sometimes even modern windows can't handle amiga file/dir names 🤣)
Maybe someone can patch the game and replace the 0x7F character with something more compatible in the meantime 😀
cT89QGt.gif Amstrad PC7486SLC-33 wanted , click me for AmiBay ad!
Reply 3 of 7, by NewRisingSun
DOSBox. Adding the following patch fixes the issue:
--- dos_files.cpp.old	2016-02-09 22:10:07 +0000
+++ dos_files.cpp 2016-03-12 13:05:51 +0000
@@ -164,6 +164,7 @@
c=tempdir[i];
if ((c>='A') && (c<='Z')) continue;
if ((c>='0') && (c<='9')) continue;
+ if (c==0x7f) continue;
switch (c) {
case '$': case '#': case '@': case '(': case ')':
case '!': case '%': case '{': case '}': case '`': case '~':
Note that "fixing" means that the game's INSTALL program is able to create the directory now. If the game has already been installed, you must create the subfolder yourself:
cd picture
mkdir ⌂
And why is this thread appearing in two forums at the same time? I'm pretty sure I created it under "DOSBox Games/Apps", not "DOSBox Multiplayer".
Reply 4 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Moved this to DOSBox Games/Apps. You put it in multiplayer, presumably by mistake, and now there is just a placeholder there that redirects here.
FYI, oddball characters normally get added as a case in the switch. There are a few in there already.
Reply 6 of 7, by Joey_sw
I remember encountering similar situation, to get around it,
instead of mounting usual directory,
i would mount and boot from hdd image that contain barebone bootable MS-DOS (the boot records; IO.SYS; MSDOS.SYS; COMMAND.COM; and some other files that needed during CONFIG.SYS & AUTOEXEC.BAT phase),
and have the game installed on said images.
-fffuuu
