First post, by Doublehawk
I just downloaded DOSBOX due to problems with QFGIV by SIERRA. I can't run the game from DOSBOX because it says SIERRA uses the batch file automatically... has anyone played this game from DOSBOX? If so, what did you type into the command line in order to get it to run? Thanks.
