First post, by raygundan
I've been setting up a bunch of my old games in DOSBox, and have had very good luck so far. I have run into an odd issue with Space Quest IV, though-- no matter what sound support I enable (SB, GUS, Roland, etc...) and what I configure in the "INSTALL" tool, the music is *always* PC Speaker.
I'm using DOSBox 0.61 and Boxer 0.61.5. I have the 1995 CD talkie "Sierra Classics" version of Space Quest IV. Running on an Athlon XP 2000+, WinXP Pro, 1.5GB RAM, generic Realtek mobo sound card.
Normal sound comes through the SB emulation just fine. If I disable PC Speaker support, the music disappears, even if the game config is set to use SB or Roland. And I never get anything but the "beep boop" of the PC Speaker, no matter what I set the music config to for the game.
Other games (Discworld 1, for example) use the Roland and Soundblaster perfectly, so the problem seems game-specific.
