First post, by Psychenous
I recently downloaded the Ultima Collection on my PC (the OS is Windows 10 btw) and the other games work fine when mounted on DOSBOX, but every time I try to start up Ultima 8 DOSBOX will say:
"FILES=5!
You must set FILES=40 in your config.sys file.
Rest Avatar you will need it."
I looked at the CFG file in the Ultima 8 folder and it is a bunch of gibberish. And I have tried turning EMS in DOSBOX Options to =false like I have to do with the two Ultima 7 games. I get the same result either true or false.
Anyone who has run into this problem and knows the solution please help me.
