First post, by ryf
Hello !
I'm having problems with the game
Joe and Mac - Caveman ninja PC DOS
The thing is I made it run quite well at 2500 cycles (P4 2.6 GHz), BUT I just can't figure out game controls !
The game seems to be set by default on Joystick control... but the problem is... I don't have a joystick 😁
The game start menu seems to offrer option for changing controls keyboard to joystick back and forth, but NO key will make cursor change position... 🙁
So, my questions are
1. is there an option in DOSBOX to emulate joystick with keyboard( I doubt it)?
2. if not, do developpers inted to add that kind of support to Dosbox(which would come in handy 😉 )?
3. does anyone knows the controls of the game, or has heard of a DOS TSR prog to emulate joystick with keyboard ?
thank you for your interest in my pledge 😉
_____________
RyF
http://www.abandonware-france.org
http://www.atp-fr.Com
http://www.gameproject.fr.st
Reply 1 of 7, by Jorpho
That is indeed unfortunate...
I shall see if the preferences can be changed using a joystick. In the meantime, why not look for the arcade or Super NES versions (which are no doubt far superior anyway)?
Reply 4 of 7, by iampiti
I have that game.
And the controls for the first player are the arrow keys, ctrl, and alt.
Anyway there's a weird thing about this game. I have to run it with less than 4000 cycles or it won't past the intro screen. I don't know if this has something to do with your problem but I would try changing the cycles if you haven't done it.
Iampiti
Reply 6 of 7, by iampiti
Sure. Here you are
Zipped because the board wouldn't allow me to upload it otherwise.
    PREFS.zip
    188 Bytes
    383 downloads
Iampiti
