First post, by Spiky
I use DOSBox 0.74 in RetroPie on Raspberry Pi3. In order to make Ignition run without calling several commands every time, I created a script:
#!/bin/bash
/opt/retropie/emulators/dosbox/bin/dosbox -c "imgmount d /home/pi/RetroPie/roms/pc/Ignition/Ignition.iso -t iso" -c "mount c /home/pi/RetroPie/roms/pc/Ignition/game" -c "c:" -c "IGN_DOS" -exit
It is working all good until I decide to stop playing and quit the game. As you can see, I added -exit option, but as I quit the game, the DOSBox console remains open and it won't let me back to RetroPie menu, unless I manually type exit in there, which is not what I want, since I play on joystick. I also tried -c "exit", but no effect as well.
Any idea how to make it work and close the DOSBox terminal once I exit the game?
