First post, by pac00zilla
I'm having problems with this game in the box I play it normally, but at the beginning the music is accelerated along with the voice of the guy at the opening of the game
Does anyone know how to solve this?
wrote:in the box I play it normally
So, are you using DOSBox for this, or are you using DOS hardware? If you're using DOSBox, you should start by lowering the number of cycles. If you're using hardware, you're going to have to provide some more information.
Also, are you using original installation disks?
wrote:wrote:in the box I play it normally
I'm using the dosbox, yes and the original cd
Lowering the CPU cycles won't help. Instead run the game's setup program and select Sound Blaster Pro instead of SB16 as the game's sound device.
