First post, by invicta66
I have successfully installed DosBox Turbo and the Game One Must fall 2097 on a Nvidia Shield.
However when i want to start the game, i get following Error:
"Sorry, this Machine has less than the minimum XMS requirements.
213k, 218240 more bytes are needed to run OMF 2097"
Over the DosBox Turbo Manager APP i opened the DOSBOX.conf and adjusted memsize vom 8 to 200
But it doesnt work.
I found another DOSBox.conf File in the folder, where DosBox is mounted. This file i have adjusted too. After a tried to run the game, my editor tells me, that this file has been modified, and if i look out, the old parameters a set again. Making this file "write protected" over the editor has no effect. It will be reseted on the next game start anyway.
I think, this is the problem, why i cant run the game. But i dont know how to adjust these parameters permanently.
Someone has an idea?
thanks a lot.
Edit.
With an other DOSbox emulator the game works but very slow and with no sound. The DosBOX Turbo Emulator is a way better.
Is there an option to modify the DOSBox.conf on DOS - Console Line?
