First post, by multi007
Hi Im looking for some help -- the game is Return of the Phantom of the Opera. (cd rom talkie version)
I unzipped the main folder and it created a return of the phantom folder. inside that folder was a c and cd folder.
if i drag and drop the return of the phantom folder into dosbox icon, the game runs great (I just need to increase cycles to get it up to speed).
but for some reason I just can figure out the proper settings to get it to run in a front end.
the front end i use is dbgl.
you dont need to "install" the game for it to work. i suspect my problem is with the mounting. i run the game inside the front end and it
opens then closes the program instantly. is there anyone who can help? Thanks,
multi007
