First post, by zoubou
Hi, when i use DosBox in full screen, it stretch my games to fullscreen perfectly. My desktop resolution is 1360x768.
However, when i use the frontend D-Fend Reloaded, playing full screen put the game too large, or too small. If the Full Screen resolution is set to "Original", the left and right side of the screen are outside my screen size, some part are not visible in my screen, for example in Prince of Persia i can't see my life points. I tried changing Full Screen resolution with another value, but they all just make a tiny square in the middle of my screen, even with bigger resolution like 1366x768.
Without D-Fend Reloaded, when i look at the file dosbox.conf, it says fullresolution=desktop, that's why dosbox work perfectly, because it stretch the game to the same resolution as my desktop resolution. I don't know why D-Fend Reloaded doesn't do the same thing, Is it possible to have a working resolution with D-fend Reloaded? Searched for hours but haven't found a working solution.
