First post, by Mergeth
Hi!
If I try to install "Die Fugger 2" with DosBox with 32768 colours on my Win-XP system, it sais that I lack 8mb main memory (memsize is set to 32) or a standard-vesa driver. It seems that the vesa driver is missing. I thought DosBox emulates that and does not need a driver?
If I try to install it using 256 colours, everything works. I tried downloading different versions of univbe, but I could install none of them. I have an ATI-Radeon-Graphics-Card.
Thank You,
Mergeth.
Reply 1 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox only emulates the 256 color modes
the 8 mb they are talking about is videomemory
Water flows down the stream
Reply 2 of 13, by Mergeth
thank you very much for that quick answer! are there alternatives to dosbox which emulate other colour-modes?
Reply 3 of 13, by eL_PuSHeR
Have you tried running it using VDMSound or even natively?
Reply 4 of 13, by Mergeth
Starting the Program without any loader or with VDMSound is the same at the moment. However, I have not tried to change any VDMS-Options.
If I start the installer, I get the first Screen, but I can't move the cursor.
If I start the program installed with dosbox, there is just a fullscreen dos-box which is black and a cpu-usage of 100%, but the intro does not show up.
Reply 5 of 13, by eL_PuSHeR
Did you try some VESA problems "workaround" tools like VBEPlus or NOLFB? If you are not sure about what they are do a forum search.
Reply 6 of 13, by Lebostein
Hi,
now 6 years later, it's possible to run Fugger 2 with DOSBox and 32768 colors?
Reply 7 of 13, by wd
Rank DOSBox Author
DOSBox Author
Try it.
Reply 9 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Mac problem
1+1=10
Reply 10 of 13, by Lebostein
h-a-l-9000 wrote:
Mac problem
Yes! You have right! 😳
I have tested it with Wine (The Emulation of an Emulation 😁 ) and it works: http://www.lebostein.de/temp/Fugger_32768_wine.png
Is this a Mac bug or can I bypass it someway?
Reply 11 of 13, by Lebostein
Is this already posted in the bug section?
Reply 12 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
yes, we know of broken mac colours for higher vesa modi.
Reply 13 of 13, by Lebostein
And now? 6 years later? Bug is fixed now?
With the last version of DosBox 0.74-1 the bug still exist... are there patches or something?
