First post, by gorzka
good eveninb,
I have a problem with the game "Die Kathedrale" in DosBox. When I start the game I become an
GIF-I/O-ERROR: 2
Can anybody help? Thank you
I have Windows 10 64 bit
Reply 1 of 8, by Jorpho
That is almost certainly an error message unique to your program that has nothing in particular to do with DOSBox itself.
All I can suggest at this point is following the 60 Seconds Guide:
60 seconds guide to getting your game to run in DOSBox
If you downloaded this game illegally from somewhere instead of installing from original disks, then your copy of the game may be incomplete or corrupt, and you should ask the people who run the site about it.
Reply 3 of 8, by Jorpho
gorzka wrote:
But the same copy runs under Linux without problems.
You mean in DOSBox for Linux? Then it is almost certainly a mounting problem. Perhaps you have installed the game to a folder to which DOSBox does not have write permissions. The easy way to check would be to run DOSBox as an Administrator, but it would be much better to use a folder in your Users directory, as in the 60 Seconds Guide.
Reply 4 of 8, by gorzka
That is my problem. The folder(s) are in my Download Folder and have no write permissions. I have also run DosBox as Admin and have the same problem
If you want you can download it here https://mega.nz/#!xo1kGZYA!RFxPqfpBLh9_iMtLdW … 6L1BorwnztJ3wXo (Windows)
https://mega.nz/#!N0FCzCAC!9M3ou0wfRwoE7461tC … 8yvTxhCFerlMFv4 (Linux)
Reply 5 of 8, by Jorpho
gorzka wrote:
That is my problem.
If that is your problem, then you can solve it by following the 60 Seconds Guide.
How did you come to this conclusion? How can you even put files in your download folder if you can't write to your download folder?
The Admin user should have write permissions everywhere.
