First post, by smegley
I am trying to play Tubular Worlds. I remember it from years ago with fondness. I am running Windows 2000. So I try to start it in DOSBOX. And it starts Ok. Slow. Of course. Now I have a joystick plugged in. You need to go to Options to select a joystick. My problem is, joystick doesn't seem to work. Or at least, not the first time I installed and was trying this game.
When you pick your joystick, in your game, you can't go up. You can only go forward or down. Also, back in the menu system, you move down, and it stays at the bottom menu selection.
Another time, I play the game, and joystick works perfect. No problem. I didn't do anything different with the game. So folks, have any idea what to fix here?
