First post, by MasterO
- Newbie
Win 7, 64-bit
Dosbox 0.74
http://www.dukertcm.com/knowledge-base/downlo … warrior-addons/
The above link has the Wanton Destruction add-on installer, but if I try to run swwd.exe (which is a self-extracting winzip installer), I get an error:
"Error 0 running command SETUP.EXE"
So I open up swwd.exe in WinRar and extract all the files to a folder. I then put this folder in my mounted duke32 Dosbox folder and within Dosbox, attempt to run the setup.exe file that is in the wanton folder.
The next problem I run into within Dosbox is "illegal command: win SETUP.EXE". I can open WANTON.EXE normally within Dosbox, but I can't press enter to start the game, because I haven't been able to setup the keyboard using wanton's setup.exe.
Is there anyway to install this addon using Dosbox, then? Eduke32 does not currently support Shadow Warrior or its add-ons yet (even though it is being currently worked on).
Also, am I correct in assuming that swwd.exe is a Windows 95 program and cannot extract normally in Dosbox?
