First post, by Serious Callers Only
Anyone that tried installing ReactOS on dosbox? And if you did, could it be done on the normal filesystem without all that bootloading or does reactos insist on direct 'hardware access' to a image file? (kind of a tragic waste of a opportunity if it does).
I want to boot into a portable (emulation) wine replacement that doesn't need image files, doesn't need any low level, error prone hardware manipulation bull and has filesystem transparency dammit.
I'll gladly sacrifice compatibility with the few bad apps that want that direct hardware access for the much superior replacements that are the emulated virtual devices. Oh demon tools doesn't work on the fakewindows device? How tragic, let me just change the cd from cdemu outside here on linux, stuff like this.
