First post, by ajc138
Hello, I just discovered DOSBox after I had a hankering to see if I could play some really old games. I downloaded v0.74 and installed it but when I ran it, all that appeared was a blank screen. So instead of seeing
as I expected, I see
I've spent all afternoon searching this forum and the web for solutions and have not found any. I've tried modifying numerous options of the config file, disabling windows firewall, uninstalling & resintalling in a different location and turning off my AV software but nothing has worked - the blank screen comes up every time. I'm running:
  • Windows 8.1
    i7 4710 2.5 GHz
    16gb RAM
    nVIDIA GeForce GTX 970M
I'm hoping it's something simple that I'm just missing. Fwiw, I'm neither a programmer nor a dos pro; I'm just a typical computer user. Any help is appreciated. Thanks!
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It's usually either that you need a different output optin in dosbox config or the nvidia driver messing things up. Some kind of setting inthe nvidia stuff
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by Jorpho
There have been numerous threads here describing this same problem, swiftly remedied by changing output=surface to output=opengl or output=openglnb. Is that something you tried?
Reply 3 of 5, by ajc138
I had not tried that but thanks Jorpho, that did the trick!
Reply 4 of 5, by Jorpho
... I am rather puzzled as to how you managed to "spend all afternoon searching this forum and the web for solutions" and "tried modifying numerous options of the config file" without coming across that. I hesitated even to suggest it.
Reply 5 of 5, by ajc138
Because for some reason I thought that setting dealt with the window that the game would be played in and not the actual dosbox window. So I got it stuck in my head that wouldn't affect anything so I didn't change it. Obviously a mistake.
