Windows 10 Dosbox
Having problems with a specific game or application? Post your problems here!
Re: Windows 10 Dosbox
Postby Radio » 2017-8-01 @ 17:05
Qbix wrote:Something on your system (videocard drivers ?) on windows 10 isn't very compatible with DOSBox.
This is not a common problem, as most of us use DOSBox on windows 10 without a problem.
I've tried compatibility mode with every available Windows, but the result is still the same.
And I don't think it's the drivers either, because ever since I bought my new system I've changed my drivers several times and all of them seem to handle the problem with the same way.
It must be something with the system itself. This ASUS G752 I have came with a ROG Gaming Center program within the Windows themselves. This program helps me monitor the system's temperature, create different profiles for gaming, some new kind of V-Sync called G-Sync and many other features for GPU and sound card.
One of those things must be responsible for the pauses I'm experiencing in DosBox, especially since you're telling me that this is not a common problem with Windows 10 users.
And before you ask, yes I've tried disabling G-Sync, no luck!
Radio
Postby DosFreak » 2017-8-01 @ 17:11
Disable everything in "Startup" in task manager and reboot. If issue fixed then slowly go through "startup" and re-enable until you encounter the issue again.
User avatar
DosFreak
Postby kode54 » 2017-8-02 @ 02:47
collector wrote:Or use msconfig.
msconfig doesn't let you manage startup apps on Windows 10, instead it kindly directs you to the Startup tab of Task Manager.
User avatar
kode54
Postby Radio » 2017-11-30 @ 21:08
I've tried everything, including what DosFreak suggested but the problem persists. I even tried updating Windows 10 to version 1709 hoping that they'll recover the old "disabe desktop composition" option in compatibility mode, but nothing. Why is it doing that? Why did DOS games ran so seamless in Windows Vista and now they have this delay thing? What's the difference between those two? I'm thinking maybe it's not a Windows issue but something that has to do with all these ASUS ROG programs my machine has.
Radio
Postby Osprey » 2017-11-30 @ 21:48
As I said earlier in the thread, I've had the same graphical issues as you in the past, but I've found ways to avoid them. Right now, I'm using the latest plain SVN build of DOSBox with output=overlay. Try that.
Osprey
Postby Radio » 2017-12-01 @ 09:58
Osprey wrote:As I said earlier in the thread, I've had the same graphical issues as you in the past, but I've found ways to avoid them. Right now, I'm using the latest plain SVN build of DOSBox with output=overlay. Try that.
And how am I supposed to rip the DosBox from all the GOG games that I have and put this SVN build? GOG installs a specific DosBox with all the settings and the only thing I can change is Dosbox.conf. And then there are about 300 (and more games) that I got from http://www.old-games.com/. They don't require any installation, but they run through a .bat file named START THE GAME.
Radio
Postby Osprey » 2017-12-01 @ 21:46
How am I supposed to know that my solution wasn't suitable for you? Since I took the time to even give you one, you could've at least said, "Thanks, but I'd rather try to solve it without changing anything about DOSBox because I have a large GOG and illegal 300+ game collection that I can't modify."
Osprey
Postby Radio » 2017-12-02 @ 12:34
Osprey wrote:How am I supposed to know that my solution wasn't suitable for you? Since I took the time to even give you one, you could've at least said, "Thanks, but I'd rather try to solve it without changing anything about DOSBox because I have a large GOG and illegal 300+ game collection that I can't modify."
I don't mean to be disrespectful and certainly I don't except to have the solution straight from the sky. I've tried a lot of options and I've made several modifications to my system, but none of them seem to do the trick. The SVN you propose is something unknown to me. I'm not an expert in DosBox like you people, that's why I'm asking for your help.
Radio
Postby olddos25 » 2017-12-29 @ 06:18
Please, please, there is no need to be hasty.
Currently mod on several Discord servs and a forum, so you can trust me if you want a DOSBox mod here!
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
EPForums: http://www.epforums.org (as emulationfan)
olddos25
Postby DanutzC » 2018-1-20 @ 13:14
Hi. Although this problem has been identified under Win10 I am also experiencing it under Win 8.1. I am not running games with Dosbox, only using it with Clipper compiled and linked executable applications. Even I am not enlightened which could be the solution to this problem, here are a few observations which may be of help. There is no need to run any task to turn Dosbox window to black. Simply test this: open Dosbox, minimize it, switch the focus to any other window/icon on the desktop, then maximize the Dosbox and here you are. The darkest window you've ever seen, cold as ice, not responding to any kb input. By contrary, if you minimize and maximize it repeatedly, no matter how many times, WITHOUT switching to another window, you'll have the Dosbox fresh and clean, capable of receiving all your inputs.
DanutzC
Postby emendelson » 2018-1-24 @ 13:16
For running Clipper apps, you'd probably be better off with vDos (www.vdos.info).
emendelson
Previous
Return to DOSBox Games/Apps
Who is online
