First post, by luckz
What is that ??
When I begin a old dos game, DosBox gives me that signal and closed.
"Fatal signal:Segmentation Fault (SDL Parachute Deployer)"
How can I fix it and make the game run?
Reply 1 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
if it's every game => check you videocard if it support 320x200.
else post the name of the game.
Water flows down the stream
Reply 2 of 13, by luckz
My display card is a SiS530/620 on board card and that game is a Chinese game so I dont know the exact name in English
Here is the download link of the game:
www.starinfo.net.cn/photography/gif/天晴传.zip
Reply 3 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
does it display chinise characters ? when working ? That might be a problem. as dosbox has little experience in that matter.
Reply 5 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
could you give at an english name. my system doesn't support those links very well.
Reply 7 of 13, by luckz
Here is the file information of the game:
Volume in drive H is ORFD
Directory of H:\
APPARE EXE 15,738 12-12-96 11:37a
ENDING DAT 7,938 10-18-96 5:28p
INSTALL EXE 33,257 12-12-96 11:21a
NEKORUN DAT 33,612 12-04-96 3:50p
OPENING DAT 11,718 11-16-96 4:27p
OR DAT 25,227,292 12-12-96 12:16p
ORBTL DAT 180,110 12-10-96 3:42p
ORFIELD DAT 176,230 12-12-96 11:20a
ORTITLE DAT 37,408 12-10-96 3:42p
SFIGHT DAT 45,906 12-04-96 3:50p
10 file(s) 25,769,209 bytes
0 bytes free
Reply 8 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
you mean this game ?
Well it runs in my version of dosbox. So I advise you to wait for the next verson of dosbox.
it needs the directory mounted as -t cdrom and ems=true
Correction it runs in 0.61 as well
I've mounted it as follows
mount c /home/qbix/dosgames
mount d /home/qbix/dosgames/ord -t cdrom
started it from c:\ord
selected the last entry in the menu (what ever that maybe (something without cd.) and started the game.
    37.58 KiB
    ord ?
Reply 10 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
could you tell what solved your problems ?
As that might be something to remember for other people with problems
