First post, by rus_159
Hi, basically I want to know what I'm doing wrong, i follow the steps laid out by the guides, I can mount my hard drive easy enough and access the directory where the game is at (quake) but it just doesnt run. I type in quake.exe and nothing happens, then after a minute or so the log window in the back starts generating hundreds of "Illegal read from xxx" statements.
Any ideas on what I'm failing to do? 😕
Reply 2 of 12, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Predator wrote:
quake needs a fpu, dosbox doesnt emulate that
Wrong. DOSBOX emulates FPU! There must some other bug. But I think that the Quake would be probably too slow anyway (just guessing - I did not try it).
Mirek
Reply 6 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
well it uses some fpu instruction only present in pentiums 😀
I added as wd pointed out.
Water flows down the stream
Reply 7 of 12, by wd
Rank DOSBox Author
DOSBox Author
Most likely they wanted to be sure that you have a
fast machine by restricting the game to a pentium
(or at least recommending one...).
Dynamic core did work pretty well with this game btw.
wd
Reply 8 of 12, by Iron
If you are talking about quake1 it sure as hell did not require a pentium.. I remember playing quake2 with a pentium 100, and that was quite a bit later.
It does need a floating point unit, but other than that a 486DX-2 >50MHz should be fine. Cant remember about visual quality issues though.
But I do think there are a lot of better ways to play quake now than playing the original in an emulator just browse around the web and you'll surely find some neat stuff 😀
Reply 9 of 12, by Predator
robertmo wrote:
I think Quake needs Pentium instructions. I am not sure whether DOSBox emulates Pentium instructions.
ouch! ok, why run quake if it requires a pentium cpu ? why not run glquake or x port ? 😁 :joyjoy:
Don't be so hard
Reply 10 of 12, by DosFreak
Quake 1 ran on my ol' 486 DX4/100 and on a friends DX2/66.
It works in latest CVS but it's sllooooow.
Make your games work offline
Reply 11 of 12, by priestlyboy
Mhm, The fast pace action games are quite slow when get more recent. heh. Some day we'll get it worked out eh?
Ieremiou
Helping Debug DOSBox.
