First post, by Jeff
Well seems my thread was deleted. And you know I may not have all the items it says for me to have in the guidlines. I think this is enough information. Besides I don't know where to get all of the information you are asking for in your guidlines thread. And I won't be ignored like that again and then be deleted. I waited for a response for days before someone deleted it. Not a good way to start things off with someone new to your forum. 😀 Now please help me.
I recently bought this game called Star Wars: X Wing Collector's CD. You see a while back I did have it, but the computer that I had it on was old and died. So I never got to finish the game. Now that I have it I am having trouble installing it. Here's what it says...Oh before I tell the below you might want to know that my computer is a Pentium 4 with over 50 GB and is a Windows XP Professional. I don't know if this will help.
The game is old. I was made in 94. But it works on my other computer the 98. I would like it to work on this new one with the better screen. The flat screen. Anyway when I started to install this is what it said:
Install has detected that you have Extended Memory available that could be configured as EMS Memory. Since X Wing CD can only use EMS, we recommend that you configure your system to use EMS. Please read the Read. Me for more information.
Press any key to continue
Install has detected that you do not have enough EMS Memory available to run X-Wing CD. Please read the file READ.ME on how to make more EMS Memory available. One option is to select "MAKE A BOOT DISK" from the main menu of this program. X-WING WILL NOT RUN WITHOUT MORE MEMORY AVAILABLE.
Do you want to continue with the installation anyway?
So anyway I read the read me and it said:
VIII) Not Enough EMS Memory Problems.
X-Wing CD requires at least 900K of available EMS memory to run, and
2000K of available EMS memory is recommended. The install program lists
how much EMS memory is currently available in your system. The largest
amount of EMS memory required is 2500K.
If the install program detects that you have no EMS memory at all then
you must install a memory manager to provide EMS memory. You can either
use the memory manager provided with DOS (called EMM386) or you can buy
a memory manager utility from a third-party. To use the memory manager
provided with DOS, do the following:
At the beginning of your CONFIG.SYS, add the following lines:
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE 2048 RAM
DOS=HIGH
and reboot your computer by holding down the CTRL and ALT keys and
pressing the DELete key (CTRL-ALT-DEL).
Run the install program to check if you have made enough memory available.
If you are already using a memory manager, but the install program says
that you do not have enough EMS memory available, consult the manual that
came with your memory manager. Make sure you have specified the necessary
options to provide EMS services and that you have specified 2048 as the
amount of EMS to be provided.
I put DEVICE=C:\DOS\HIMEM.SYS
DOS=HIGH into my config.sys and it still didn't help. I don't know if this means anything, but my AUTOEXEC.BAT has nothing in it. Before this neither did config.sys.
Somewhere I also read that DOS has a built in Memory Manager called EMM386.exe that you can use to change Extended Memory into EMS Memory, how do I get to it?
Now with the other option that said I could make a Boot Disk for the game so that it could configure my computer for the game. I tried it. It said:
Could not locate path.
Also during the Install it does not detect my sound. I know I have sound. I mean I hear it in game called Starsiege, all the time. What should I do?
Also if this DOSBox can help me please dumb it down for me because it's all greek to me. Also is this DOSBox like other memory managers that partition your drive to do it's work?
Please don't ignore my thread and delete it again. Don't delete my thread again please or I may go elsewhere. I'm sorry if I am coming off angry, but I hate being ignored then deleted like this.
Oh and the game I am wanting to play comes from a CD. The game even when installed on C: can only work with the CD in. The directory for the game is: C:\XWINGCD. The execute icon for the game is XWINGCD. It's a MS DOS Batch File (.bat). The CD is in CD Drive E. My Zip Drive is on D and my CD RW drive is F. And if I have to do something each time to get the game to work please tell me what to do please.
