First post, by tvisitor
Hey all,
Trying to run Prince of Persia in DosBox 0.61. It seems like AdLib emulation is working, but I can't seem to get Prince to use the SoundBlaster (i.e. no scream when he falls, etc.)
Motherboard: ASUS P4G8X
Processor: P4 3.0GHz
Video: Gainward 5200 Golden Sample (nVidia based); 128 MB
Sound Board: Built in (AC97)
OS: XP Pro
I've already noticed that DOSBox has the BLASTER=A220 I7 D1 T4 already set when it starts. I don't see anything in Prince that legs you change this.
I haven't tried other games that use SB.
Reply 5 of 7, by tvisitor
I tried another game that had soundblaster, and that game worked fine. I suspect it's due to no setup utility on my version, but perhaps command line parameters. I'll have to check for another version of Prince of Persia and see.
Reply 6 of 7, by eL_PuSHeR
Looking inside Prince of Persia main executable (v 1.3), i see the following command-line parameters:
stdsnd
adlib
imbg
gblast
sblast
tandy
disney
mvpas
compuadd
midi
Which should be self-explanatory. I think PoP accepted parameters "as-is", i.e, without slash
Example. PRINCE.EXE adlib
