C.I.T.Y. 2000: London garbled videos.
Having problems with a specific game or application? Post your problems here!
Postby KainXVIII » 2018-1-23 @ 11:59
Most of the game videos works fine, but some particular looks like this (tried in latest Dosbox ECE and Daum Dosbox 2014)
User avatar
KainXVIII
Re: C.I.T.Y. 2000: London garbled videos.
Postby ripsaw8080 » 2018-1-23 @ 23:17
The game appears inflexible regarding VESA mode parameters; but seems to work correctly with the machine=svga_et4000 setting and running the TLIVESA driver in the \SETUP\VESA\TSENG directory on the cdrom. You can run the INSTVESA program and choose option K (Tseng) to create a VLON batch file that simplifies loading the driver when running the game.
User avatar
ripsaw8080
DOSBox Author
Postby KainXVIII » 2018-1-24 @ 09:10
Thanks, here how it looks now
User avatar
KainXVIII
Postby ripsaw8080 » 2018-5-12 @ 23:13
There's an update for the game that fixes the broken movies when using default settings in DOSBox; might be other fixes in there as well: viewtopic.php?f=33&t=18143
User avatar
ripsaw8080
DOSBox Author
Postby KainXVIII » 2018-5-13 @ 16:24
ripsaw8080 wrote:There's an update for the game that fixes the broken movies when using default settings in DOSBox; might be other fixes in there as well: viewtopic.php?f=33&t=18143
Thanks, missed that thread.
User avatar
KainXVIII
Return to DOSBox Games/Apps
Who is online
