First post, by Devvy
I have 25th Anniversary Enhanced CD Rom, i can install it from the cd onto the hard disk but then when i try to change to the TREKCD directory it says unable to change to TREKCD, i try and take Read Only off of the folder but it keeps popping back on the minute i close properties.
Also if i copy the files out of the folder and attempt to run STARTREK.exe it says
" No CD Rom drive detected. Make sure that you have run MSCDEX.exe and that the correct CD-ROM device driver is present in your CONFIG.sys file."
Also with the White Label Judgement Rites CD when i attempt to install it, it opens cmd.exe and askls for a language, whe i select one it says "Unable to Save configuration file" and closes.
