First post, by silencer_ar
Hi! I'm trying to run the menu for an old shareware colection, The Shareware Extravaganza (disc 1). The link to the iso file can be found here: https://archive.org/download/Shareware_Extrav … 0%281993%29.iso
The problem is that when I run EXTRA.BAT, that in turn runs RUNPL.EXE, I get the message "Could not locate CD Drive!"
I tried playing with the options mentioned in the wiki (http://www.dosbox.com/wiki/MOUNT#Mounting_a_CD_ROM_drive) but with no luck yet.
Do you have any out of the box suggestions? I'm using DosBox 0.74.
I have tried installing DOS 6.22 in Virtualbox with MSCDEX and it works fine (although games run slow, that's why I don't want to use virtualbox)
Thank you!
