Skynet won't install.
Having problems with a specific game or application? Post your problems here!
Postby Un Information » 2018-2-20 @ 08:31
When I try to install the 1995 Bethesda game Skynet with install.exe it simply says: "DOS: File not found: data\screen.col." Does anyone know what this means?
Un Information
Re: Skynet won't install.
Postby squiggly » 2018-2-20 @ 08:49
The file has obviously been terminated. What happens when you DIR in data...what do you see?
squiggly
Postby Radical Vision » 2018-2-20 @ 10:12
Seems the Terminator have been terminated Skynet this is what the problem is.....
Just bring another Terminator to deal with him...
User avatar
Radical Vision
Postby Un Information » 2018-2-27 @ 10:42
squiggly wrote:The file has obviously been terminated. What happens when you DIR in data...what do you see?
I just see the contents.
Un Information
Postby Osprey » 2018-3-02 @ 22:27
An easy way to install the game is to simply copy the entire Skynet folder from the CD and then apply the unofficial patch. That will bypass the game's installation program that is giving you the problem.
https://community.pcgamingwiki.com/file ... atch-2017/
Osprey
Return to DOSBox Games/Apps
Who is online
