First post, by Faceless
I have a Pentium 2.4ghz with 768mb RAM.
I have a ATI Radeon 9800 XT (256mb) and Sound Blaster Audigy.
I am running Windows XP Pro SP1.
When trying to run Starlord one of two things will happen depending on what exe I run.
If I run setup.exe it says "SETUP: DSFH string not passed" and does nothing.
If I try to run the game the screen goes blank with a few red squares on it then dosbox just terminates.
I haven't changed anything in the config file so everything is at the defaults.
Help...
