First post, by typh0id
Greetings,
Forgive me if I'm retreading old ground (I did a search but the keywords are all pretty generic and nothing helpful to me jumped out of the results), but I am trying to run Legend of the Red Dragon (4.07) locally in DOSBox and it is giving me troubles.
I've tried running LOCAL.BAT and LORD.EXE /L (which I recall being the way to run it locally back in the day) but in all cases I get: INTERNAL ERROR #38019 CANNOT CONTINUE.
Am I missing something obvious or does LORD not run in DOSBox? I would think that running it locally wouldn't require anything special out of DOSBox, but then, I certainly don't know everything.
Anyway, thanks for any help anyone can give me with this. I spent countless hours as a teenager playing and modding this game and would love to revisit it.
Reply 4 of 8, by DosFreak
It does but not in 0.74. You'll need to use the latest SVN or at least later than the below date.
Found this in the changelog
2011-01-16 20:49 qbix79
* [r3667] include/dos_system.h, src/dos/drive_local.cpp: Add dummy
support for openmode 4. Legend Of the Red Dragon 4.07 uses this.
Make your games work offline
Reply 5 of 8, by typh0id
DosFreak wrote:
It does but not in 0.74. You'll need to use the latest SVN or at least later than the below date.]
I may just stick with 3.55. I have to admit in all the years I've been tinkering with DOSBox, I've never ventured into SVN territory. I know basically nothing about them.
Reply 6 of 8, by gdjacobs
Nothing much to know. In most ways, it's a plug and play replacement, except with a few more features and bug fixes. Why not install a copy alongside and test a few DOS programs you normally run?
Reply 8 of 8, by gdjacobs
As of this post, r4085 is the latest commit. You should run an SVN build that is checked out and built at a point close to this release.
