You might wanna check this out....guy claims he can get this game running in XP without DosBox or anything....I tried it but it didn't work.....the Soundblaster Fix did not work either......so I just thought maybe I'll just run the demo setup like it said, and of course it did fail like it says....I then copied the install files from the full version CD like it says......tried to run it not in dosbox like it says and set everthing up with the soundblaster emulator, didn't even load.....I thought, oh well, but it gave me an idea, I used the demo like it says, copied the files from the cd and then ran it in DosBox and for some strange reason the game runs now with sound and doesn't freeze when I move a unit......I think it's kinda strange, but at least I got it working with sound now I guess....just posting this in case no one can get it to work with sound....you might wanna try running the demo setup instead of the full version setup....it works, for some strange reason, just give it a try if you are having sound problems....
http://www.planetcnc.com/cnc2sw/dos_xp.html#install
