First post, by PinkTaco-
when i use dosbox to install wc2 deluxe edition CD, i run winstall after mounting my d and c drive. when the install loads i select the install drive, but the directory part has "Camedat" already typed in. and i can only delete up to "Cam" and when i try to type the pathname i cant type a colon. if i just hit enter to skip, i get another selection to save time/space i can choose either and then i get an error saying "wing commander 2 game not found. you must enter the directory containing the wing commander 2 game."
then it just sends me back to the drive selection screen. does anyone know whats wrong? im clueless. anyone that has this game, what and how did you install?
edit: dosbox gives me some write protection errors on the 2nd box(not the one you enter commands in) this *could* be the problem. any ideas on a workaround?
