First post, by Jens
Hello!
EarthWatch (a sundial) is the ONLY of my 600+ DOS programs that won't run. The (rather simple) program (EVW35.exe) starts in full-screen under Windows XP (no need for Win95 compatibility mode) and shows a colourful sunlit/dark map of the world = it works. But under DOS-Box all i see is black. The prog starts, switches to VGA-graphics mode (after a second DosBox window becomes slightly larger) and then there is black (even at day). It does'nt crash, CPU is almost idle... it just does nothing (i can see) until i quit it regulary (Q or ESC)... There are no error-messages and i'm through with any imaginable DosBox setting (that i know of) ...
Greetings from 52°12'N 8°43'E Jens
