First post, by Jens
Hello!
Calgames.exe complains, that i am short of 199K to run it. MEM says that i got 632K conventional mem and 63K UMB. What now?
Someone mentioned, that Calgames complains about too little RAM when it finds too much? Err... (unfortunately the someone did not mention how to handle this). The .exe seems to be OK, i got versions from different sources. Are there any Dos-Box settings that i have not found yet? (i already switched on/off everything) Or can i load (how) any (what?) memory-eater parallel to Calgames? Thanks for your tips!
Jens
