First post, by spudman
I have the original TFTD CD and could install just fine and got the sound card set up and everything. When I exited the installer it said to type "terror" to start the game. I did, but all the prog did is pause for a second the went back to the command line.
The app is a .BAT and I tried to run it using the "loadhigh" command but got the same result but DosBox said it was an illegal command <- worked with Jones in the Fast Lane. Any ideas would be great, Thanks.
PS
I have the Collector's Edition vers., but even with all the updates and tweaking, it's barely playable 😠 .
A spoon is a tool.
