ICR2
First post, by scottw666
Using the dos indy car racer 2 with the latest cvs build I get :
DOS/4GW Professional Protected Mode Run-time
Copyright (c) Rational Systems, Inc. 1990-1994
Copyright (c) 1994-1995 Papyrus Design Group, Inc. All rights reserved.
Version 1.0.2
Unable to find IndyCar.exe in ''. on launching the program. In debug mode it looks like its trying to find an IndyCar.etx file (which doesn't and AFAIK shouldn't exist).
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
dos4gw always looks for original exe .etx so that 's not allarming.
are you sure there isn't file missing are a directory structure ?
Water flows down the stream
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
hmm probably you mounted the game directory as root
like mount c c:\path\to\game
try mounting root to root
like
mount c c:\
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
the game probably looks for files at certain places (e.g.) where you installed them. if you start dosbox and type
mount c c:\dir then you change your c drive according to your program.
