First post, by HeavenSmile
Hello! (^-^)ノ
New to the forums. I hope I posted in the correct place. I recently downloaded DOSBox and I'm running my favorite childhood CD-ROM game, Brain Dead 13. I followed the following guides when setting up all the parameters:
60 seconds guide to getting your game to run in DOSBox
https://www.dosbox.com/comp_list.php?showID=2757
The game looks better than I could have imagined, runs perfectly both visually and audibly. However..
While I'm playing the game, there's clearly moments when the CD-ROM drive has to be accessed to retrieve information. It's a game akin to Dragon's Lair. It's essentially a movie and you make inputs during a specific timing window in order to either play the rest of the animated video, or play a death video. If you're trying to make an input at certain key places, the game will momentarily freeze and you'll hear the CD-ROM boot up, then the game resumes.
Here's a link to the CD-ROM I'm using as well:
https://www.walmart.com/ip/USB-3-0-External-D … k-Air/563948314
Is there a way that I can change either settings within DOSBox or settings specific to my CD-ROM hardware to have it always be running the disc so there's no interruptions during gameplay? OR should I just copy the contents of the CD-ROM to my PC's HDD and run the program from there through DOSBox? I'm not sure how to accomplish the latter. All of this is very new to me.
Reply 2 of 2, by HeavenSmile
Worked like a charm! No pauses I can now die happy! I also tried putting everything on a jump drive and changing the mount paths and the game is perfect. I guess I would just have to edit the config file before playing the game off of a jump drive on someone else's PC to account for the letter automatically assigned to the jump drive by the PC? I'm ok with that. Thanks a million! ┌(˘⌣˘)ʃ
