First post, by Guardian_Misterioso
I've been trying to run the game "Tie Break Tennis 2" (HAMMER Technologies) without success because it gives the following error:
For this I have used both DOSBox 0.74 and the SVN Daum version testing all possible configuration options. Does anybody know what is it due to? Thanks in advance.
DOSBox version: 0.74 and SVN Daum
OS: Windows 7
Game: Tie Break Tennis 2 (CD-ROM version)
Reply 1 of 3, by DosFreak
It looks like the batch file is referencing a directory that does not exist since you are already in that directory. Also you are using LFN directory names.
I'd delete the game and install it from the original copy.
The latest official version of DOSBox is 0.74-2. We don't care about the daum version here.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 3, by Guardian_Misterioso
That is what I have done. I have installed the game from its original copy four times and it always throws the same error. What I forgot to say is that the game only has a Windows installer even though the executable is for DOS. I mean, I have to install the game through Windows and then run it via DOSBox.
Reply 3 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Not sure what's going on there, but based on how the directories are organized it seems you need to make the TIEBRE~1 directory the current directory and then start the game from there.
CD \TIEBRE~1
JUEGO\TIE2.BAT
