First post, by quinn
Hi, I'm trying to play Extreme Pinball in DosBox. (tried 0.59, 0.60 and current CVS code) under Linux, with normal, full and dynamic CPU cores, and in all cases the game works just fine... until I press a key, at which point, it crashes (back to the DOS command prompt, which will still accept commands, but nothing is readable)
Has anyone else encountered this, or found a way to stop it from happening?
