Darklands help
First post, by redradish
Hi,
I have recently installed Darklands and it runs fine up until a combat sequence then it hangs, always. Has anybody had this problem?
I am running a mobile AMD Athlon XP 3000+ 1.45GHz
512MB RAM
ATI Radeon 9000
Windows XP Home Version 2002
The game is Darklands 438.07
And I am using Dosbox 0.61
I dont really know where to start with this problem. I have tried using some of the switches with Darklands and changing the install settings but nothing helps.
Thanks,
Reply 2 of 3, by mightymouse090
i had downloaded darklands and played for quite a while. when i tried to open it on dosbox and play again i could not find the exe file. i have re-downloaded the game and unzipped and replaced but no luck. any advise? i use vista if that will help
